Emergency Stop Keyboard Shortcut?
Postby hothiscold » Mon Apr 22, 2024 2:36 am
Is there a keyboard shortcut for an e-stop?
hothiscold
Re: Emergency Stop Keyboard Shortcut?
Postby dezsoe » Mon Apr 22, 2024 7:18 am
Yes. Go to Settings / I/O Trigger / Hotkeys. In the Keycode column press the Set key then the keyboard key that you want to use. In the function column press the Set key for the list of codes. Search for "reset": you'll find the toggle (144), on (512) and off (513). Select which you need. Press Apply or Save.
Postby hothiscold » Mon Apr 22, 2024 4:55 pm
Thanks for the reply!
So you're saying that if I trigger a 512 function, it will be an e-stop? And if I trigger the 513 function, it will remove the e-stop condition?
hothiscold
Postby dezsoe » Mon Apr 22, 2024 5:46 pm
Yes.
