I get the error function code 120 / 127 not supported. Any hint, where I can find more info? I see the communication counters counting up.
Re: Modbus error
Posted: Sun Apr 21, 2024 7:30 pm
by dezsoe
Where and when do you get this message? If using the Modbus plugin then what is the version of the plugin?
Re: Modbus error
Posted: Sun Apr 21, 2024 7:47 pm
by Socke
I‘m using uccnc 1.2116 and the Modus Master Plugin, that came with uccnc.
I get the error, as I start the loop with functions enabled. With functions disabled, I get no error.
Re: Modbus error
Posted: Sun Apr 21, 2024 8:10 pm
by dezsoe
OK, getting closer. In 1.2116 the Modbus plugin version is 1.6.0.0. But I still don't know what did you set in the functions. Could you upload your profile with the saved Modbus settings? Also, what is connected using Modbus?
Re: Modbus error
Posted: Mon Apr 22, 2024 6:56 am
by Socke
I can't get a grip at the machine now, only in the evening. In the function i want to read coils, slave adress 1, starting register slave and uccnc at 0, everything like in the manual. The slave is an I/O-board: https://de.aliexpress.com/i/1005005338884242.html [youtube]https://www.youtube.com/watch?v=Pz3R7jXr-1g[/youtube] (youtube-link not working?)
Re: Modbus error
Posted: Mon Apr 22, 2024 7:20 am
by dezsoe
Thanks, I'll check it.
Re: Modbus error
Posted: Mon Apr 22, 2024 8:34 am
by dezsoe
On Youtube press Share, select Embed then copy. This long string has to be between the youtube - /youtube.
As I see Battwell could control this beauty, so it's possible. I can't imagine how he could do it, because the manuals don't help too much...
Re: Modbus error
Posted: Tue Apr 23, 2024 5:56 pm
by Socke
So, what can I do but asking at YouTube and hoping for an answer?
Re: Modbus error
Posted: Tue Apr 23, 2024 6:11 pm
by dezsoe
As I wrote: upload your profile. It has your settings for the Modbus plugin, so I can compare it with the manuals and (hopefully) find the problem.
