Probe 1 or Probe 2 Don't Work if Both are Used
Postby bhdavis » Fri Apr 12, 2024 5:01 pm
I posted this elsewhere but realized this might be the better forum.
UCCNC Ver 1.2111
I'm still trying to get my 2nd probe working.
Probe #1: CNC4PC TP-1 using the C48 control board. Set up on Pin 15 / Port 1
Probe #2: Generic NO push button switched pad probe. Set up on Pin 12 / Port 2
My issue is that either one will work if the other one does not have a Pin / Port assignment in the I/O Configuration settings. The other one has to be set a Pin 0 / Port 0 for one of them to work. Even if I assign a Pin / Port number not actually in use on one of them the other one will not work. I have tried every combination of pin, port and ACTIVE LOW check mark combinations.
By not work I mean I get this error messag shown in the image below.
So I think this is a UCCNC issue where perhaps I'm missing getting something set up correctly. Or perhaps it's an old issue that has been resolved in newer versions of UCCNC.
I'd rather stay with UCCNC Ver. 1.2111 as I have a lot of time in customizing the screen. But I could upgrade to the current version if the consensus here is that needs to be done.
BH
bhdavis
Re: Probe 1 or Probe 2 Don't Work if Both are Used
Postby bhdavis » Sat Apr 13, 2024 2:19 pm
Here is the headway I've made.
I thought I'd done every possible combination of ACTIVE LOW and pin/port settings but thanks to Gerry's suggestion on the other post I made a chart and tried every possible combination.
What I've found is that both probes need to be ACTIVE LOW in order to work. But if both are ACTIVE LOW at the same time then neither one works.
Probe 2 is a simple NORMALLY CLOSED touch button passing 5v+ back to PORT 2 -- PIN 12 that I'm adding to the system as a tool measure probe with my tool rack.
Probe 1 is the CNC4PC TP1 with the C48 control board going to PORT 1 --- PIN 15 that I've always used for my material touch down. This doesn't read NO or NC when tested so I suspect there is no circuit completion without it being powered up.
Other than getting rid of the TP1 / C48 setup and doing a second probe just like Probe 2 and using a different pin/port, or simple putting that new one in series with the current tool measure Probe 2, do you have any suggestions?
BH
bhdavis
Postby bhdavis » Sat Apr 13, 2024 3:06 pm
SOLVED. Sort of anyway.
I tested for the 2nd NC touch probe and everything works as it should. I'm swapping out the TP1 / C48 for the 2nd NC probe and that will solve the problem. I suppose I'll leave the TP-1 in place in case I ever want to do some 3D probing but it will be disconnected until then.
bhdavis
