home direction
home direction
Postby antonfat » Mon Apr 08, 2024 6:39 pm
Greetings. I have this problem: during homing the axes go to the opposite side compared to how I select the direction box.
antonfat
Re: home direction
Postby dezsoe » Mon Apr 08, 2024 7:24 pm
It's likely that your home sensor is already active when you start homing. Check the diag page.
Re: home direction
Postby antonfat » Tue Apr 09, 2024 2:51 am
Hi dezsoe. No because I generally move the axes a little outside the home sensors before turning off the machine.
antonfat
Re: home direction
Postby cncdrive » Tue Apr 09, 2024 9:08 pm
Check the following: When the axes are off the home switches then check if the home LEDs in the diagnostics are on or off, they should be off when the axes are off the home switches.
If they are on then you have the home switches polarity configured in reverse. Then reverse the home input polarity with inverting the active low checkbox of the homing in the axis settings.
Also you then need to reverse the homing direction to make the axes home to the proper direction.
Re: home direction
Postby antonfat » Wed Apr 10, 2024 4:51 pm
thanks cncdrive I changed the configurations and now it's ok.
antonfat
