Hi all guys, I've been going crazy with my CNC for 3 days and I don't know where to turn my head anymore.
It is self-built in 25mm ergal, very stable.
I spent a day calibrating it after the move and it's perfectly calibrated,
I also redid all the stepper calibrations with centesimal precision on all axes (calibrated with Mitutoyo comparator)
Now the problem arises, if I tell it to move 20mm via MDI it moves 20.00mm, very precise on all axes.
If instead I make him make a 20x20mm test square directly from the post processor file, he makes it 20.2 x 20.2mm on both X and Y, tested at any speed, it doesn't change.
I use CAM fusion360 (non-hobbyist) and UCCNC post processor with UC100.
Tried the kernel at both 25, 50 and 100...it doesn't change.
Checked backlash, and adjusted on x-axis.
It gives me the impression as if in the passage between the fusion file that I download onto a flash drive, and the CNC's PC, something happened that generates the error.
Can anyone help me?
Thank you
