Plugin DLL Defective.Rload
Postby Louie F » Thu Feb 22, 2024 9:24 pm
Hi, I changed to a new PC Windows 11, I am using a UC400ETH and when I go to start Mach3 I get "Mach3 UC400EH V1_022.dll - Defective". So I tried a few things I tried deleting the plugins in the \Mach3\plugins\ folder and re-installing the UC400 plugin. It didn't work so I uninstalled Mach3 and now my UC400ETH doesn't communicate no blue light. I also have UCNCC software installed using the 22-screen set it connects but when I change profiles it loads the UCNCC standard screen but it loses connection any help will be appreciated.
Louie F
Re: Plugin DLL Defective.Rload
Postby cncdrive » Fri Feb 23, 2024 7:41 am
Make sure to install the UC400ETH plugin with the UCx00 plugin installer, because it installs some prerequirements not only the plugin.
Also enable the .net framework 3.5 in the Windows features.
Postby Louie F » Fri Feb 23, 2024 1:09 pm
Thank you reply I will try that today.
Louie F
Postby Louie F » Fri Feb 23, 2024 9:15 pm
It worked thank you.
Louie F
