1.2116 update
1.2116 update
Postby ejg3855 » Sun Feb 18, 2024 1:09 am
I recently updated to 1.2116 from 1.2113 and it deleted all my screen sets and machine configurations (pins, ports, xyz calibration, etc.) it basically gave me a default interface.
I fixed up most of these issues but I've discovered a M9 call issue that doesn't seem to be working properly.
If I turn M7 on my mist turns on, if I toggle the "mist" button my mist turns off.
If I turn Mist on and type M9 in and hit return the mist button color toggles, the software shows that the output changes state but the mist doesn't turn off. If I then toggle the mist button on/off it turns off.
https://youtu.be/Eu2IPdAELZk?si=2A7jK1r79LWPiXRo
ejg3855
Re: 1.2116 update
Postby cncdrive » Sun Feb 18, 2024 3:34 am
Hi Just tried it and could not reproduce the issue.
Please post your profile file.
Re: 1.2116 update
Postby ejg3855 » Mon Feb 19, 2024 12:58 pm
profile attached.
I hope its something obvious
02122024.pro
(44.33 KiB) Downloaded 157 times
ejg3855
Re: 1.2116 update
Postby cncdrive » Mon Feb 19, 2024 1:17 pm
Dezsoe, please tell this.
Re: 1.2116 update
Postby dezsoe » Mon Feb 19, 2024 2:01 pm
I could reproduce it, it's really bad. (I'll contact PB.)
Re: 1.2116 update
Postby dezsoe » Mon Feb 19, 2024 2:54 pm
I forgot to mention that you have the M8 output on Port 1 Pin 1 which cannot be used as a normal output. The O1 output works only for charge pump.
Re: 1.2116 update
Postby ejg3855 » Mon Feb 19, 2024 8:20 pm
Yea I have the pin setup and wired to a solenoid but I do not use it, noted and will fix when I get a moment.
as for the M9 and Mist is this something that will be fixed and patched quickly or should I roll back to 115 ?
ejg3855
Re: 1.2116 update
Postby dezsoe » Mon Feb 19, 2024 8:32 pm
It will be fixed in 1.2117 with some other bugs, but I can't tell you when it will be released. For production you should use the latest stable version which is 1.2113. You may also use 1.2115 which has some known bugs, but in most cases works fine.
