Values not being accepted/applied
Posted: Fri Feb 16, 2024 2:59 pm
I'm having a problem trying to set some values in the settings. In particular right now, the Y+ soft limit. I know that you have to press enter to confirm the value so that is not it. I put in the new value (larger than existing one), press enter and then click to apply settings and the value reverts back. I've tried doing it when the machine is both at the limit and not. When I do it when it is at the limit and the softlimit indicator light is on, when I click apply settings, the light goes off for a second, then the value reverts and the light comes back on.
Sometimes it might apply on the first try. Sometimes the second or third. Or sometimes like right now where no matter how many times I try to change it, it refuses to set and apply.
I've had this problem on and off since I've started using it. The times it happens that I can think of are when I'm trying to change things on an axis to do with either limits, velocity, acceleration, etc. Stuff like that. Other settings like enabling/disabling softlimits seem to work. I don't know if this could somehow be to do with my set up since there doesn't seem to be other people having this problem. What happens when those types of values are set. Do they get set or are communicated in any way on the motion controller (AXBB-E) before being validated? If this isn't a bug and it's being reverted for a reason, there should really be some kind of message saying why it's being reverted. It would save a lot of frustrations.
I have seen that there is a new version available in one of the forum posts but it's not the one available from the product page which makes me think it's still in beta testing. Should I be trying that version?
I'm at a loss.
Kevin
I'm at a loss.
Kevin
