UCCNC error "Screen file not found"
Postby VAMAKA » Sat Jan 20, 2024 12:51 pm
An error message appears during the loading phase of the program
"Screen file not found" and download stops.
What could I do ??
VAMAKA
VAMAKA
Re: UCCNC error "Screen file not found"
Postby ger21 » Sat Jan 20, 2024 3:21 pm
Are you starting UCCNC with a desktop shortcut that points to the correct profile?
Postby cncdrive » Sat Jan 20, 2024 6:27 pm
Usually it means a corrupted profile file when the profile file is broken or empty.
The software reads the screenset file name which is empty and so it gives you this error.
Open the .pro profile file in the UCCNC/Profiles folder with a text editor and check it's content.
Profile file corruption happens if the computer gets shut down while the UCCNC is saving content into the profile file.
You can enable the Backupprofile plugin, it makes backup copies of the profile file which you can use to copy/replace the original broken one.
Postby VAMAKA » Mon Jan 22, 2024 10:09 am
Hi, the problem persists.
[Screensetsettings]
mainscreenfilename=Default2019
splashscreen=0
[axessettingscontrolX]
Axisenabled=True
Stepportnumber=1
Steppinnumber=2
Steppinnegate=False
Dirpinnumber=3
Dirportnumber=1
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Limitminuspinnumber=0
Limitminuspinnegate=False
Limitpluspinnumber=0
Limitpluspinnegate=False
Homepinnumber=0
Homepinnegate=False
Homedirectionpositive=False
Homeautozero=True
Homingvalue=0
VAMAKA
VAMAKA
Postby dezsoe » Sun Jan 28, 2024 11:14 am
I removed your other thread. Creating a new thread with the same question is useless.
You didn't reply Gerry. Are you sure that the shortcut opens an existing profile? If the profile does not exist then you get the same error message. Check the profile name after the /p switch.
Also check the Screens folder if the screenset file exists. The file name must be "Default2019.ssf". Check if there are any spaces that you don't see, but the file name will not match.
Postby VAMAKA » Mon Jan 29, 2024 4:45 pm
Hi, thanks for the instructions, problem fixed.
the whole Screens folder was gone ??, I quoted
of its demo versions.
VAMAKA
VAMAKA
Users browsing this forum: Google [Bot] and 14 guests
