by cncdrive » Tue Jan 02, 2024 8:17 am
If you will home the machine then the Homing buttons will activate.
If you check the ResetDereferenceAllHomes then activating the Reset (Pressing the reset button) turns the homing buttons off like if the machine was not homed yet,
CheckHomeonCycleStart does not allow to run a g-code Cycle until you home the machine and so the homing buttons are active.
