Fluctuating spindle speed.
Postby Delco » Tue Nov 14, 2023 5:12 am
I have just tried to get uccnc to control the spindle spped of my dc motored lathe.
It has a potentiometer that controls the rpm normally , I removed the output pin the variable 12v signal is on and connected it and the earth pin of the potentiometer to analague 1 and analogue earth on my uc300.
UCCNC send a 0-10v signal to the circuit board inside the lathe and the speed is approx correct with a min duty % of 10 and a max duty % of 80 and it will control the speed up and down via UCCNC
The issue I have is the rpm fluctuates approx 50 rpm ( it does not do this with the original potentiometer) , I have tried the pwm frequency from 10-200 and it makes no real change.
Any ideas ?
what does the PWM frequency do ? optimium setting ?
Delco
Re: Fluctuating spindle speed.
Postby Delco » Tue Nov 14, 2023 6:18 am
After watching a few youtube videos I found one franco did with the centroid that had similar issues - his solution was to remove the power supply ground.
I tried that and the issue went away - also the set min/max pwn % also had to change to get the spindle spped calibrated correctly .
Do I run with the main power supply ground removed ? or do I ground the lathe to the power supply ground and reconnect it ?
Delco
Postby cncdrive » Tue Nov 14, 2023 4:23 pm
Do you have a schematics of the spindle controller?
Postby Delco » Tue Nov 14, 2023 10:00 pm
NO , I have verified the machine is earthed to ground but the board earth is not grounded.
Delco
Users browsing this forum: iopturbo and 24 guests
