Problem between vcarve and uccnc
Posted:
Wed Nov 08, 2023 12:08 am
by MJones99
When I design 20 four inch tags in vcarve, all on 1 board and open with uccnc the machine cuts a 8 in tag. It follows the correct path on the screen which is 4 inches. No clue how to fix it. I have tried a couple projects and it cuts twice the size of the design. Worked fine two weeks ago. Any help is appreciated.
Re: Problem between vcarve and uccnc
Posted:
Wed Nov 08, 2023 3:55 pm
by mickecarlsson
Have you changed the preprocessor in Vcarve? Does the preview in Vcarve look OK?
Posted:
Thu Nov 09, 2023 9:58 am
by Battwell
confirm you have not got scaling enabled?
are your steps per unit correct ( check by jogging a distance on the screen and confirm travel of machine is the same)
