UC100 License File
UC100 License File
Postby needleworks » Sun Nov 05, 2023 3:47 pm
Can anyone help me with a license file issue ? I was just about to try out the new lathe software but am getting the error "no valid license file found"
I have been using the UC100 for 5 years or more running Mach3 with no problems, but now I am getting this error. I can't remember if I ever had a license file or not to run Mach3 !
I have searched my PC for a license and all I can find is a license file for my mill, which is running with a UC300 5LPT. If I need to purchase a license, then so be it, so could someone tell me how to go about it ?
needleworks
Re: UC100 License File
Postby ger21 » Sun Nov 05, 2023 4:53 pm
If this is for Mach3, their should be a file called Mach1lic or something similar, in your C:\Mach3 folder.
Postby needleworks » Sun Nov 05, 2023 6:19 pm
ger21 wrote:If this is for Mach3, their should be a file called Mach1lic or something similar, in your C:\Mach3 folder.
No it's not for Mach3 Gerry, I was hoping to try out the new UCCNC Turn function on the lathe. I'm going to assume my Mach3 license won't work for that.
needleworks
Postby dezsoe » Sun Nov 05, 2023 6:31 pm
Yes, the Mach3 license is for Mach3 with or without any UC device. You'll need a UCCNC license for your UC100. You can buy it at CNCdrive or you local distributor.
Postby needleworks » Wed Nov 08, 2023 8:21 am
Is there a problem with the license? I paid for on Monday but still nothings arrived! Sorry if I'm being impatient, keen to try this out.
needleworks
Postby cncdrive » Sat Nov 11, 2023 10:18 am
Sorry for the delay.
I just sent you the license key in email yesterday.
