Tabel Size display in toolpath
Re: Tabel Size display in toolpath
Postby TadasM » Sat Mar 04, 2017 6:20 pm
I don't know if such thing is possible on UCCNC, but I would appreciate this function too...
TadasM
Postby cncdrive » Sat Mar 04, 2017 11:10 pm
No, that is not possible.
If this would be implemented then the table boundaries drawing should be regenerated every time the offset is changed,
because the table boundaries are the machine coordinates and the toolpath is in fixture coordinates.
I'm not saying it is not possible to implement this, but definitely not very simple and I'm wondering how useful would this be for the users? You guys tell me. :)
Postby ger21 » Sun Mar 05, 2017 3:49 am
If you do decide to add it, make sure it's possible to turn it off, as I don't want to see it. :)
Postby TadasM » Sun Mar 05, 2017 8:42 am
cncdrive wrote:No, that is not possible.
For me it is only "good to have" feature.
Maybe a simpler way would be just add boundaries from softlimits (as Vmax says) ? The boundaries would appear only after homing the machine and taking values from softlimits ? (however I'm not sure how the path viewer works...)
TadasM
Postby A_Camera » Mon Mar 06, 2017 10:50 am
ger21 wrote:If you do decide to add it, make sure it's possible to turn it off, as I don't want to see it. :)
Same her. I can see no use for it at all.
Postby A_Camera » Mon Mar 06, 2017 10:52 am
But what would be the point unless you work on something which is almost as large as the table you have?
Postby Derek » Mon Mar 06, 2017 11:54 am
I can see this being handy if you do a lot of sheet work and use the maximum machine size. Although if you run with soft limits then UCCNC will kick out an error when you push "Run" if your code is outside the limits. This can get a little dodgy though if you are running multiple work offsets and multiple tool offsets in the same code.
Derek
Postby Derek » Tue Mar 07, 2017 2:15 am
How do people that don't use soft limits keep from overshooting during rapid jogging and end up into the hard limit switches? I have to really concentrate a lot more than if I have them on. Right now I can rapid 3 axis at once and if I overshoot one it's not the end of the world. Without soft limits I would have to jog one axis at a time carefully.
Derek
Derek
Postby beefy » Tue Mar 07, 2017 8:53 am
Derek wrote:How do people that don't use soft limits keep from overshooting during rapid jogging and end up into the hard limit switches? I have to really concentrate a lot more than if I have them on. Right now I can rapid 3 axis at once and if I overshoot one it's not the end of the world. Without soft limits I would have to jog one axis at a time carefully.
Derek
That's what I was thinking too. I have my soft limits set up a few mm short of where the limit switches would trip (= table lost position & need to re-home). Makes life easy.
I would much prefer the automation of soft limits, to having to keep an eye on the screen while I did high speed jogging. I always watch my table when jogging in any case, never really look at the screen.
But then I do the sheet size work where the edge of the sheet is a short distance from where the limit switches would trip.
beefy
Postby A_Camera » Tue Mar 07, 2017 2:34 pm
Vmax549 wrote:HIYA Derek you do it the same way that you drive you CAR in city traffic and not run into anything (;-).
(;-) TP
My car has soft limits in X and Y plane... Yes, true, I am not joking. There is though a speed limit (I think it is 160kmh), after which it is disengaged.
