Intermitting Probing issue
Postby infamous_panda » Sun Oct 15, 2023 12:54 pm
I have an intermittent bug when using the stock probe function. Most times it will lower the tool slowly to the tool setter twice retract and set 0. However sometimes after using the machine for a few operations and then hitting probe the machine will plunge down fast once, depress the toolsetter pretty low (not enough to damage thankfully) and stop to give an error that the probe was active. It does not retract or set zero. Once this behavior starts it always behaves this way until I restart the program.
Maybe there is a setting that I am accidentally changing after running a few programs?
Using it with and Custom AVID CNC, UC300ETH
infamous_panda
Re: Intermitting Probing issue
Postby Delco » Mon Oct 16, 2023 3:16 am
What version of software are you using , the latest development version - well a year or so old - has a probing bug.
Delco
