UC300ETH-5LPT Spindel control Huanyang
Posted:
Fri Mar 03, 2017 8:18 am
by alex_s
my google fu is not strong today, but i know there was a post here or on cnczone where someone set up a uc300eth with a Huanyang VFD directly to control CW, CCW, RPM and start stop.
Anyone might have it bookmarked somewhere ( i forgot ;/ ) RPM should be easy over one of the analog outputs (0-10V)
BR
Alex
Re: UC300ETH-5LPT Spindel control Huanyang
Posted:
Fri Mar 03, 2017 9:08 am
Alex,
And what is the question exactly?
Or you just looking for the link to a cnczone forum thread?
Do you want to control the spindle with the UC300ETH or with Modbus?
Posted:
Fri Mar 03, 2017 10:41 am
by alex_s
UC300Eth directly via BOB
Speed is controlled with 0-10V on the vfd, and direction / start stop with IO pins on the vfd
looking for the link, because there was something with the ground that you need to take care off, so something does not interfer
Posted:
Fri Mar 03, 2017 12:51 pm
It depends on the VFD, but in 99% they have isolated analog circuit where the analog input is isolated in the VFD from everything else.
What you will have to connect isolated are the M3 command pin and the direction command pin,
because in most VFDs these are pulled to e.g. 10Volts or 24volts internally, so a standard TTL output of a UC300ETH-5LPT would damage from a direct connection,
so ideally you should use an optocoupler with an NPN output ( e.g. on a BOB) to connect those signals.
Posted:
Fri Mar 03, 2017 1:32 pm
by ger21
alex_s wrote:UC300Eth directly via BOB
I think that it depends on the specific breakout board that you have.
