Cycle stop acting as reset when THC on
Postby b57378 » Wed Oct 11, 2023 5:50 am
Hi All, hope you are well.
Just a follow up on one of my previous post with an issue I have been experiencing :
"I am having a crazy issue - I've set up a machine on the default plasma screenset version 1.2113.
I do not have any keyboard mappings, I am using the onscreen controls - when pressing "cycle stop" in the middle of a rapid or toolpath the machine will stop suddenly without decelerating(As if the reset was pressed or a limit was hit).
I am not doing anything funky, all the default macros are in place - this is just a normal setup."
After further testing, I've found that it only happens when THC is active, this happens on 2 independent machines I have.
When THC is off, the machine stops with deaccel with the cycle stop button.
Any ideas on what I'm doing wrong?
Thanks in advance!
b57378
Re: Cycle stop acting as reset when THC on
Postby cncdrive » Wed Oct 11, 2023 8:31 am
Please post your profile file to let us test the issue.
Postby b57378 » Wed Oct 11, 2023 9:55 am
Hi, Thanks for the reply.
Please see attached .Pro file.
KB_PLASMA.pro
(34.79 KiB) Downloaded 250 times
b57378
Postby b57378 » Wed Oct 11, 2023 5:02 pm
Just on another note,
There is a minor issue that I have been struggling to iron out( Happens on different machines ):
The post processor I use with the plasma uses a G31 to probe the Z torch - maybe 1 out of every 50 probes will trigger in the air without actually coming into contact with the plate I am cutting.
I originally thought the issue was noise but all our cables are screened and earthed on one side - I have yet to use the de-bounce setting.
I have also replaced the microswitch a couple of times to isolate the issue.
Our routers(Which use UCCNC) have never missed a tool probe - which leads me to believe that the issue might not be electrical noise.
Is there any chance you could also investigate this with the attached .Pro file?
Any feedback will be greatly appreciated, Thanks in advance!
b57378
Postby cncdrive » Thu Oct 12, 2023 2:55 pm
Dezsoe, please test this and let me know.
Postby b57378 » Thu Oct 19, 2023 9:46 am
Hi Deszoe, Any updates on your findings?
b57378
Postby dezsoe » Thu Oct 19, 2023 10:56 am
Sorry, I forgot it. I'll check it as soon as possible and I'll be back with the results.
Postby b57378 » Fri Oct 20, 2023 5:32 am
Thanks Dezsoe
b57378
Postby b57378 » Fri Oct 27, 2023 6:14 am
Hi Dezsoe
Did you find anything yet?
I know these things can take time to find.
b57378
Postby dezsoe » Fri Oct 27, 2023 2:17 pm
Yes, I can confirm that the issue exists.
