Tool table ????
Tool table ????
Postby kig23 » Mon Sep 18, 2023 11:02 am
i'm using uccnc version 1.2115. How the Tools 1-48 and Tools 49-96 tabs are related to the Tool table - detailed window. There is nothing in the use manual.
kig23
Re: Tool table ????
Postby dezsoe » Mon Sep 18, 2023 11:45 am
The data is the same. The Z offset is called "length" in the detailed table:
Re: Tool table ????
Postby kig23 » Mon Sep 18, 2023 1:14 pm
Hi Dezsoe,
i see in the Neon screenset they have fields for Slot and Description. The question is how these fields are related to the Tool table - detailed? Does changing values from Tool table - detailed reflects to the Tool tab and vice versa?
kig23
Re: Tool table ????
Postby dezsoe » Mon Sep 18, 2023 2:06 pm
You can see the relation on the picture. There are no fields in UCCNC for the other parameters, they can be edited only in the details window. However, if you have a plugin or macro to read/write the details then you can place fields on the screen to edit these parameters. I don't have the Neon screenset, so I can't check how it is done.
Re: Tool table ????
Postby kig23 » Mon Sep 18, 2023 5:58 pm
Thanks. I solved it with plugin
kig23
