Step/Direction 5V0 connection on AXBB-E?
PostPosted: Sun Apr 23, 2023 9:58 pm
by spillage
In the AXBB-E manual:
11. Example Wiring shows it connected to 5V0 on the “Power Input” block of terminals (or the power supply).
9.2 text would suggest using 5V0 on the “Power Out” block of terminals.
8. The label and logic might suggest using 5V0 on the “Port 1 non isolated outputs” block of terminals.
Which is the correct location to connect the 5V0 of Step/Direction drivers?
Re: Step/Direction 5V0 connection on AXBB-E?
PostPosted: Sun Apr 30, 2023 11:34 am
The labels with the same name are common on the board.
For example all the 5V0 are the same potential, so you can connect any of them, however ofcourse it is the best to connect to the one in the closest proximity to the step/dir signals.
PostPosted: Sun Apr 30, 2023 1:27 pm
by spillage
Thank you for the clarification.
As always, your time is appreciated.
