In the AXBB-E manual:
11. Example Wiring shows it connected to 5V0 on the “Power Input” block of terminals (or the power supply).
9.2 text would suggest using 5V0 on the “Power Out” block of terminals.
8. The label and logic might suggest using 5V0 on the “Port 1 non isolated outputs” block of terminals.
Which is the correct location to connect the 5V0 of Step/Direction drivers?
