Hi all,
Just getting a 4th axis going. I am using a UC300ETH and UB1 board.
I have setup the CNC with X slaved with A, Y, Z and using B for rotary.
Everything seems to be working as it should with the exception of the settings shown in the pic.
When first booted up, that is how the setting are.
The A axis is now claimed as the rotary axis when B is. But A is still slaved to X?!
- Even with the settings like shown in the pic, everything mechanically works as you'd expect.
A is still slaved with X, and the B rotary rotates as it should regardless of the settings.
I can change everything to what one think the setting should be, but after a reboot, everything
reverts back to what you see in the picture.
The settings aren't sticking for the Rotary B axis but still works as it should?!
I tried selecting each box individually then apply, then save.
The settings remain this way until a reboot, after the reboot, the settings are back as seen in the pic.
Is it necessary to have the rotary on A and slave B to X instead?
- I also tried loading UCCNC as an Admin, but still no change to settings.
