Help with AXBB-E Analog Output
Postby Kristijan » Mon Apr 03, 2023 2:45 pm
Hello
I need help with AXBB-E analog pwm control for my spindle.
I have installed everything correct my spindle goes on and off on M3 output 2 on the board. I have problem with 0-10 V analog output A01 it does not give any Voltage when I am Measure with my instrument.
it stays on 0 V no matter what.I removed the jumper for 0-5 or 0-10 V but it has no difference.
Also i have put the Spidle PWM --> analog ch to 1. but does not work. When the spindle is on when i change values analog output 1 in analog I/0 monitor is changing values but on the BOB is still 0 V.
What is going on ?
Also u installed potentiometer on the VFD for the spindle and the spindle is working fine is changing the frequency.
Here are photos of setting in UCCNC.
https://we.tl/t-8eLh0Km3MW
Kristijan Stojkovski
Kristijan
Re: Help with AXBB-E Analog Output
Postby dezsoe » Mon Apr 03, 2023 4:35 pm
You need the Spindle PWM to analog out 1. Set the PWM min/max values and the spindle velocity min/max. You also have to command the program the spindle speed: you have it on 10 rpm which is the startup value.
Connections (AXBB pins in red):
Postby Kristijan » Mon Apr 03, 2023 5:24 pm
It is like this avi to A01 and acm to 5v0 but i dont get nothing from the BOB AXBB-E. if you saw the photos you can see that.
In program i put S 5000 for example but it does not change to needed speed.
Kristijan
Postby dezsoe » Mon Apr 03, 2023 7:37 pm
As I wrote: you don't have a very low rpm set.
Postby Kristijan » Mon Apr 03, 2023 8:13 pm
Where i set this ?
Kristijan
Postby dezsoe » Mon Apr 03, 2023 8:17 pm
Use the S word in the MDI.
Postby Kristijan » Mon Apr 03, 2023 8:21 pm
If i set on program Sxxxx it does not change nothing that is why i was asking i will try tomorrow on the machine once again.
Kristijan
