charge pump on.
charge pump on.
Postby Battwell » Wed Feb 08, 2023 10:50 am
i need a solid on signal. not pwm which follows the charge pump
always on when uccnc is in control.
method?
Re: charge pump on.
Postby Delco » Wed Feb 08, 2023 10:13 pm
Can you slave a output trigger so when the charge pump output is on then output # is on as well ?
Delco
Re: charge pump on.
Postby Battwell » Thu Feb 09, 2023 12:36 pm
was just wondering if its going to act as pwm instead of solid output. or if it will detect as off in the loop.
