Hello,
I want to conect my Laser to my diy Machine.
Im using a Uc-300Eth thogether with a triple beast from sorotec on my diy milling machine. I have conected the triple beast Lpt-band to the Uc-300eth on port 2. I also planed to use the a analog port pin 5 for ground and pin 6 for pwm signal. My program is mach3.
My knowledge about electronics are very bad. The triple beast gives the pwm on pin 17 or pin 1 from 0-10V. The Uc-300eth works with 0/5V ttl and my laser goes with 5-12V pwm...
My Laser is a LT-4LDS-V2 from Lasertree (using with deliverd driver board and external powersuply 24V.
In mach3 for Spindle I have chosen the pin 17 on Port 2 witch is conected via the Lpt-printerband. I want to turn on and off my laser by gcodes M11 and M10. So therefore i chosed for output#1 the unused Port 3 and pin number 1 to Switch on and off. For Spindle Setup I changed the needed things.
So my questions are:
Do I need a converter for the different voltage?
How do the digital port 3 pin 1 and Lpt-port 2 pin17 comunicate with the analog port? Do I need aditional conections/Inputs?
How can i generate the pwm?
Have anybody pictures from his connection? That would help me. I also tried with active low options and cant get him to work. When I add the powersuply the laser dont react to the Spindle Button and any gcode. The software shows that Spindle is on when using gcode but my laser dont works.
Im thankful for every help.
Greetings from Germany
Viktor
