Defining home
Defining home
Postby BJB » Fri Dec 23, 2022 4:06 pm
Does anyone know if its possible to define home using one of the offsets, such as G92 and if its possible, how?
I want to define "home" to a smaller area than the far back left corner. I can get the exact "machine coordinates" which I would like to use as the "home" position.
Any help or ideas would be gratefully accepted.
BJB
Re: Defining home
Postby fsli » Fri Dec 23, 2022 5:09 pm
Wouldn't setting the work zero location fit your needs?
Frank
fsli
Re: Defining home
Postby BJB » Fri Dec 23, 2022 5:38 pm
Sorry, where is work location found?
BJB
Re: Defining home
Postby BJB » Fri Dec 23, 2022 5:42 pm
Just realized you mean zero each work point.
I meant to re-define where the gantry goes when I click on the home all button
BJB
Re: Defining home
Postby ger21 » Fri Dec 23, 2022 7:31 pm
You can do this using the Write Offset on Homing and Homing Backoff options on the Axes setup pages.
Re: Defining home
Postby BJB » Fri Dec 23, 2022 8:18 pm
Thanks, the thing I don't quite understand is what to input in those fields. Is it the machine coordinates or something else?
Is there anywhere I can read how to do this?
Sorry to seem to be asking silly questions.
BJB
Re: Defining home
Postby BJB » Fri Dec 23, 2022 9:27 pm
Am I correct that I get the offsets I need from the offsets table? If I try it on G59, will that leave G54 as it is so that I don't screw the current settings in case it doesn't work.
Thank you so much for your help.
BJB
Re: Defining home
Postby ger21 » Sat Dec 24, 2022 11:44 am
The Home Offset value is the position of the home switch in machine coordinates.
For example, if you set the X axis home offset to 10, then the X axis home switch position will be X=10 in machine coordinates. If the machine homes in the negative direction, and you set a home backoff of 5, then the machine will be at X=15 after homing (in machine coordinates), and be 5 units away from the switch.
Re: Defining home
Postby BJB » Sat Dec 24, 2022 12:15 pm
Gerry, that's a great explanation, thank you so much.
Wont be able to play with it now till after Xmas (Sunday) so will check it on Monday and let you know how it goes.
Thanks again
BJB
Re: Defining home
Postby BJB » Wed Dec 28, 2022 11:21 am
Hi Gerry,
I have been playing with your suggestions and I think I'm must be missing something.
I have attached a screen shot of the the machine coordinates of where I want the gantry to be when told to " home"
When you have a chance could you tell me what coordinates to put where.
Many thanks
BJB
