Hello,
I have just finished build a cnc engraver using the latest Uccnc software and Axbb -e controller.
I have an issue with simple probing in the Z axis using a touch plate.
At one stage I had it working correctly. ie it would come down twice and return to the correct position showing the position on the DRO of 16.35 above the work piece. ( ie the thickness of the touch plate ( 6.35 )and the retract setting ( 10 mm ))
However now it does everything correctly but displays zero in the DRO.
I don't know what I have changed and cant seem to correct things and so can anyone offer a suggestion of what I need to do please?
Many thanks
JH
