Losing work Co-ordinates when homing
Posted: Mon Sep 19, 2022 12:06 pm
Hi all
I have been losing work co-ordinates when re-homing my machine and has been re-occuring throughout different machines and versions of Uccnc.
It will happen about 20 percent of the time, I will reference my machine, zero work co-ordinates and start cutting, since I run long jobs, I'll stop the machine and move the z axis up, shut down uccnc and power down machine.
The next day I will power up, home machine and go to original work position. The problem is this works for the most part but other times will shift the job to a random position.
This is definitely not a motor slipping as I run an Atc with machine coordinates and the tools are perfectly aligned when the work position is lost.
This problem ONLY happens when I re-home.
Any help is greatly appreciated.
