network connection not possible
Postby gilles974 » Mon Aug 22, 2022 8:33 am
hello
I received my AXBB-E today,
- 24v power supply connected
- network cable OK
the PC and the controller are connected to the switch
but no detection of the LAN the led remains off on the controller, no led is lit on the RJ45
PC is detected
network cable changed several times
thanks to +
à moi les copeaux
gilles
gilles974
Re: network connection not possible
Postby dezsoe » Mon Aug 22, 2022 12:05 pm
You need a separate 5V power supply too. The 5V supplies the whole digital section, including the network.
Postby gilles974 » Mon Aug 22, 2022 1:28 pm
hello
I advance my leds on the RJ45 are lit
the "Ready" LED flashes
but the "link" led does not light up
the detection of the AXBB-E is not done
how to change IP 10.10.10.11 to 192.168.1.xx?
the card does not identify itself on the Network and Sharing Center.
gilles
à moi les copeaux
gilles
gilles974
Postby dezsoe » Mon Aug 22, 2022 2:05 pm
The link will only light when the controller is talking to UCCNC or Mach.
The flashing Ready LED means that it is waiting for a DHCP server. No problem. In the UCCNC\Util directory there is a program called UCxxx_utility. Start it and setup the network as it is in the manual.
Postby gilles974 » Mon Aug 22, 2022 4:13 pm
Le lien ne s'allume que lorsque le contrôleur parle à UCCNC ou Mach.
- OK
UCxxx_utility. ne detecte aucun controleur
à moi les copeaux
gilles
gilles974
Postby gilles974 » Tue Aug 23, 2022 8:06 am
hello
I FINALLY managed to detect the card in the UCxxx utility
my card as IP: 10.10.10.11 with DHCP connect to a network card (10.10.10.10)
I want my card to be on the 192.168.1.x network
do I have to manually change IP and GATEWAY and do a "save network setting"??
gilles
à moi les copeaux
gilles
gilles974
Postby Dazp1976 » Tue Aug 23, 2022 2:02 pm
gilles974 wrote:hello
gilles
What network cable are you using?.
Crossover or standard patch?.
Use crossover cable for direct connection between axbb-e and pc network card.
Use standard patch to connect them via a switch.
Crossover won't work via switch, standard patch won't work direct.
Dazp1976
Postby gilles974 » Thu Aug 25, 2022 4:02 am
hello
saved, I managed to modify the IP of the box.
once the network card is installed with the IP 10.10.10.10
I put a patch cable and the LEDs flashed on the RJ45 connector and on the box, BUT still no detection by the UCxxx utility....
there I had the idea of disconnecting the 5V power supply waits a few seconds and reconnecting it, and there miracle the detection by the utility UCxxx.... has indeed taken place.
why this trick worked, I don't know
Thanks for your help
gilles
à moi les copeaux
gilles
gilles974
Users browsing this forum: Google [Bot] and 26 guests
