No Movement In Axes - UC400ETH
Postby TheNigerian » Tue Aug 16, 2022 7:04 pm
I am really confused - and embarassed - by whatever I am missing.
In 06.2020, I easily and successfully set up my k2 cnc 2514 with my newly purchased uc400eth and all three axes easily and correctly moved . I put everything in storage and relocated.
I have finally set up again in my new address and cannot get the axes to move.Nothing is damaged and the setup utility software affirms that my connections are correct.
The single difference is that I lost and replaced the ethernet cable - with a crossover cable that I had successfully tested.
Please help me.
Axes.pdf
Current default axes settings.
(483.59 KiB) Downloaded 176 times
TheNigerian
Re: No Movement In Axes - UC400ETH
Postby TheNigerian » Tue Aug 16, 2022 9:54 pm
NB:
The UC400ETH's amber light blinks rapidly and I am using the DEL Precision M6800
TheNigerian
Postby ger21 » Tue Aug 16, 2022 10:51 pm
Is the blue light on?
Postby Dazp1976 » Tue Aug 16, 2022 11:33 pm
Aren't the network perameters different depending on whether you connect via stadard ethernet over network or crossover cable directly?.
Maybe you just need to follow the setup instructions in the manual and redo it again.
Dazp1976
Postby TheNigerian » Wed Aug 17, 2022 9:19 pm
ger21 wrote:Is the blue light on?
Yes Ger; it is on.
TheNigerian
Postby TheNigerian » Wed Aug 17, 2022 9:22 pm
Dazp1976 wrote:Aren't the network perameters different depending on whether you connect via stadard ethernet over network or crossover cable directly?.
I have no objection to this suggestion.
I will review the manual and start all over.
Many thanks; I will revert tomorrow.
TheNigerian
Postby TheNigerian » Wed Aug 17, 2022 9:23 pm
Yes Ger; it is on.
TheNigerian
Postby TheNigerian » Tue Aug 23, 2022 11:41 am
Apologies for the delayed response.
I received a brand new crossover ethernet from Amazon today but need to first solve another problem that developed.
I had pressed the reset button on the UC400ETH and now need to re-establish contact; it is in the demo mode.
I will revert shortly.
Many thanks.
TheNigerian
Postby TheNigerian » Thu Aug 25, 2022 4:38 pm
Summary
Hello everyone.
To start all over, I uninstalled the uccnc app, reset the UC400ETH to factory settings (as per the instructions on page 16 of the manual) , reinstalled the app and rebooted my laptop.
But now, UCCNC always loads into DEMO mode, the blue light does not come on and only the red light is lit in the laptop's ethernet port.
The connection settings that passed muster in 10.2020 returned an error message today.
I still have no idea what i have missed.
TheNigerian
Postby TheNigerian » Sun Aug 28, 2022 7:16 pm
It is quite amazing how costly any amount of inattention can be.
By following the instructions - especially the clear illustration on page 9 of the installation manual - and setting the IP address to 10.10.10.10, I got the computer and UC400ETH to communicate.
Only the z axis moves - slowly - and the right arrow key causes the z-axis to rapidly descend.
I have movement nonetheless and will create a new post for the new issues.
Thank you very much indeed for your assistance.
TheNigerian
Users browsing this forum: Google [Bot] and 37 guests
