I'm in the process of changing from Mach3 to UCCNC and upgrading all of my electronics on my CNC lathe. I just purchased a UC400ETH controller and trying to decide between a PMDX 126 or a CNC4PC C32 dual port BOB. I am planning on using dual MPG's for X and Z so I think that I'll need a dual port BOB unless there is another way of using two MPG's. Any suggestion would be most appreciated. Bob
cncdrive wrote:I think that these BOBs can't fully work with the UC400ETH, because as far as I know they both expect the second port to be an input type port where the low 8 bits (pins 2-9.) are inputs, while the UC400ETH has a standard LPT port pinout on both ports, so the pins 2-9. are outputs on both 2 ports.
So, probably the best option is to use 2 separated BOBs which interfaces to one-one standard pinout port.
ger21 wrote:He's saying that the software only supports a single MPG, regardless of which hardware motion controller you are using.
Users browsing this forum: Google [Bot] and 16 guests
