Spindle speed staying at 6000rpm
Postby Hatchet Job » Fri Jul 29, 2022 7:56 am
First of all thanks so much with the last help you guys gave me, I could feel the collective eye roll at my dumb question.
I'm making good progress now and have a much better understanding of what's going on.
I'm having an issue where my spindle will only spin at 6000rpm no matter what.
It's a bog standard HY series VFD with a 2.2kw spindle which I've been using it for some time already on my previous MACH3 setup.
I've the AXBB set at 10v analogue out.
AO 1 to 10v in on VFD
5VO to DCM on VFD
IO2 to Forward on VFD
On UCCNC I have PWM spindle ticked, PWM frequency 400Hz.
Spindle output really enabled M3 relay pin IO2 port 1.
Spindle velocity max 24000rpm.
I can toggle the spindle on and off but the speed stays at 6000rpm and cannot be changed either by the dial on the VFD itself or the UCCNC controls.
Am I missing something bleedingly obvious again?
Hatchet Job
Re: Spindle speed staying at 6000rpm
Postby Dazp1976 » Fri Jul 29, 2022 8:11 am
Which model?.
Have you set your 'maximum hz' perameter in the vfd to match the motor?.
For example:
If motor is 400hz and vfd internal perameter is at 100hz, you would get 6000rpm. (1/4).
Dazp1976
Postby Hatchet Job » Fri Jul 29, 2022 8:26 am
Dazp1976 wrote:Which model?.
For example:
The model is HY 02D223B
I've been running this motor/vfd combo previously on my old setup so those settings haven't been changed, I just checked them anyway and they're all good.
Hatchet Job
Postby Hatchet Job » Fri Jul 29, 2022 11:57 am
The internet has delivered again and I found a PDF on another forum with the correct settings and they seem to work just fine.
https://www.cnc3d.com.au/forum/technica ... onnections
Hatchet Job
Users browsing this forum: No registered users and 61 guests
