Problem with incorrect position in all axis
Postby Berti » Sun Jul 10, 2022 8:33 am
Hello everyone,
I suddenly have the problem with my CNC milling machine (UCCNC with AXBBE Controller and AC Servos) that the current position is no longer correct for all three axes...
If I e.g. Touch a part and drive around a bit is suddenly the zero point up to 8mm wrong!
When I check an axle with the watch and drive 10mm according to the watch, the display of uccnc also partially deviates by up to 2mm.
If I drive back to zero, I also have different results (+- 1mm)
Taking into account the different axle ratio, the deviation in all three axes is approximately the same.
The strange thing is that only I had a program running, where everything fit. Then I only opened a new program and that’s where the problem began.
Of course, I have already restarted everything, after that everything works briefly as it should, but after 1-2 minutes the same problem is back...
I’m desperate...
Maybe someone can help me...
Thank you in advance.
Berti
