What Vars are used bu UCCNC, and which are safe to use?
Postby ger21 » Fri Jan 27, 2017 10:23 pm
Cahit just notified me that my Screenset macros use the same vars as his Autoleveler plugin.
Before I change them, can you tell me what is a recommended range that we should use, and which ones should not be used?
I thought this was brought up before, but I couldn't find it.
Re: What Vars are used bu UCCNC, and which are safe to use?
Postby ger21 » Sat Jan 28, 2017 12:27 am
Well, his plugin uses 900 vars, so that's 15% right off the top.
I use two that I arbitrarily picked, that fell in the range he's using.
I'm going to move the info I need into the screen, and use an LED and text field instead.
The same type problem exists across the screensets ??
Not really, because you only have one screen loaded at a time, and you can't just quickly switch screens. Screen developers should notify their customers that a new screenset should use a new profile, to avoid duplicate macros.
