Carousel Atc axis
Carousel Atc axis
Postby b57378 » Sat Jun 11, 2022 5:41 pm
Hi all, looking for some advice
I am using an Atc with the C axis enabled for tool positioning.
This axis has to be enabled for the M6 macro - one issue is since it's enabled, it will return to zero with other axes which isn't really a big issue but slows the other axes down when returning.
Is there any simple solution to this?
b57378
Re: Carousel Atc axis
Postby ger21 » Sat Jun 11, 2022 11:17 pm
Try editing the M204 macro.
Postby Vmax549 » Sun Jun 12, 2022 1:52 pm
When using a rotary axis on the carousel you do not code it in conjunction with the XYZ axis. You code it as a seperate move.
G0 X1 Y1 Z1
G1 C30 F50
(;-) TP
Vmax549
Postby b57378 » Sun Jun 19, 2022 12:20 pm
Thank you for the replies, will try this and see the results.
b57378
Users browsing this forum: Google [Bot] and 21 guests
