Dwell on spindle speed change (not tool change)
Postby rojhan » Fri Jun 10, 2022 4:51 pm
I would like to be able to insert a dell on spindle speed change, not just on/off or triggered by a tool change.
My specific use case is do a very light, fast cut of the surface (cutting the perimeter of stencil material) prior to carving the actual text and then painting. The bit/tool stays the same, but I'd like to cut the stencil at a much higher spindle speed than the carving itself. There may be other use cases, but that's my specific example.
I have set the spindle on/off dwell time and have tried setting MOP header/footer, but the dwell needs to be after the S command.
Is there any way to accomplish this? I could probably create a dummy MOP between operations that just changes the speed and then waits, but I'd like it to be automatic without needing to remember to do something special.
Thanks!
rojhan
Re: Dwell on spindle speed change (not tool change)
Postby ger21 » Fri Jun 10, 2022 5:58 pm
Add a G04 after the S command?
Postby rojhan » Fri Jun 10, 2022 6:00 pm
ger21 wrote:Add a G04 after the S command?
Yes, G04 works. But, other than header/footer is there a macro or some other way to modify the S command? Or do I need to do this on the CAD/g-code generator side?
Ideally, "here's the g-code with the different mops, tool changes, and spindle speeds. Automatically add a delay after changing spindle speed not caused by a tool change/stop"
rojhan
Postby ger21 » Fri Jun 10, 2022 10:50 pm
Add it to your post to add a G04 after a speed change?
Postby rojhan » Sat Jun 11, 2022 12:37 am
You mean in post-processing in CAM? I'm looking into that as well (CamBam).
rojhan
Postby ger21 » Sat Jun 11, 2022 12:50 am
yes
Postby Dazp1976 » Sat Jun 11, 2022 8:31 am
ger21 wrote:yes
Can this kind of thing also be bodged by using spin up/spin down perameters in the drive itself? (depending on your drive system used of course).
Dazp1976
Postby ger21 » Sat Jun 11, 2022 1:55 pm
Dazp1976 wrote:
ger21 wrote:yes
No, because UCCNC will not wait for the drive. This is the problem he already has.
Postby rojhan » Sat Jun 11, 2022 2:21 pm
I have a brute force version of this working by adding a 3 second delay after spindle speed in each MOP as part of the MOP template. I also reduced my spindle spin-up delay by 3 seconds.
It's not perfect (there is a wasted 3 seconds between MOPs if the spindle speed doesn't change), but it gives me a place to start. It looks like I'd either need to write a plugin or a post-processor that would statefully modify any S commands; keep track of previous speed and only add the delay if it changes.
rojhan
Postby ger21 » Sat Jun 11, 2022 3:19 pm
I think most people can greatly reduce spin up speed in their VFD settings. I had no issues setting my Huanyang accel time to 1 second.
