Shapr 3d
Shapr 3d
Postby MaSc » Wed Jun 08, 2022 2:14 am
I want use Shapr3D on my IpadPro to draw parts using uccnc with a Stepcraft M700
When I try to open the dxf file with uccnc I get „this is not a valid acad dxf file”.
Thanks for help!
Martin from Germany
MaSc
Re: Shapr 3d
Postby ger21 » Wed Jun 08, 2022 11:22 am
The problem is that there are many different .dxf file versions, and most software that read and write .dxf files use a specific format, and often don't follow the format 100% accurately. The end result can be a lot of incompatibility.
The only real option you have is to find another application that can open your .dxf files, and save them in a different format that UCCNC can read.
Re: Shapr 3d
Postby cncdrive » Wed Jun 08, 2022 6:46 pm
We working on upgrading the UCCAM, the next release will read most DXF versions and will also read splines and nurbs in the DXF files.
