AXBBE+UCCNC+Stepperonline Nema24 (cant get it to work)
Postby Cip » Wed Apr 13, 2022 1:48 pm
Hi, i have the setup from title and I can't get the motors to move. The motors are keeping position and if I force them they come back to position, so they have power
AXBBE has connections with UCCNC blue light on, limits+estop+probe working when I use them so it "talks" with the software.
But, the motors are dead, no movement at all, I wired them from schematics I check and double check but I cant get them to move, will put some pic with the wiring and setting maybe I'm missing something.
Image Image Image Image Image Image Image
Cip
Re: AXBBE+UCCNC+Stepperonline Nema24 (cant get it to work)
Postby cncdrive » Wed Apr 13, 2022 5:23 pm
You should configure the step/dir ports and pins according to your drives wiring to the AXBB-E, so make sure you have those configured properly.
Postby Cip » Wed Apr 13, 2022 5:50 pm
Well, that is the problem, i think I have done everything correctly. But I can't get to move them a single step.
This is the video that I followed https://www.youtube.com/watch?v=CCCO_1m ... ppeRommens + the schematics of the motor https://bit.ly/3xnVjaH
I configured the step/dir from O9with 010 and so on in pairs to 016 and set up axis "A" as slave.
I did not configure the flip switches on the driver tho, to set any microstep value. And this according to the manual can lead to no motor movement
For now, it's default how they came from eBay. (only played with one driver switches but with no result)
Sry (big beginner here) :cry:
Cip
Postby Dazp1976 » Wed Apr 13, 2022 7:30 pm
Cip wrote:Well, that is the problem, i think I have done everything correctly. But I can't get to move them a single step.
Double/triple check the wiring on the driver for your motor phases and the encoder.
Dazp1976
Postby Cip » Thu Apr 14, 2022 2:59 pm
Yea did that, only conclusion is that I have a bad axbbe board on my hands..
Cip
Postby Dazp1976 » Thu Apr 14, 2022 4:03 pm
Cip wrote:Yea did that, only conclusion is that I have a bad axbbe board on my hands..
Unusual.
What if you switch it to cathode pulse/direction (npn) instead of anode (pnp) ?.
Put outputs to driver negatives and 5v+ to positive, active low. Maybe try using enable too.
Worth a shot. I'm thinking +/- conflict somewhere between pulse set and encoder or driver could be getting disabled for some reason.
(or I'm full of crap).
Have you looked at diagnostics page and activated a sensor to see if the input state changes?. If not, it could be communication between pc and axbb-e.
Are you using a ethernet crossover cable if directly connected?.
Dazp1976
Postby DavidR8 » Thu Apr 14, 2022 4:25 pm
Your drivers have a switch for 5v or 24v input. Is that set to match the input power?
DavidR8
Postby Cip » Thu Apr 14, 2022 4:51 pm
DavidR8 wrote:Your drivers have a switch for 5v or 24v input. Is that set to match the input power?
Ok, how can I buy you some beer?
In the search for the "complicated", I forgot about the switches. Ty again everything works now.
Thank you @all for the answers https://youtu.be/g_rB4v75jqU?t=12
Cip
Postby DavidR8 » Thu Apr 14, 2022 5:28 pm
You're welcome, no beer necessary!
DavidR8
Postby Dazp1976 » Thu Apr 14, 2022 6:05 pm
That's good info.
Added this to the growing list of things to know for future reference.
Dazp1976
Users browsing this forum: No registered users and 50 guests
