Hello together,
a couple of days ago my AXXB-E Board and UCCNC licence arrived. I started the installation and hardware setup and sadly run into trouble.
Description:
I planned to use output 16 on port 1 for the A axis direction and output 17 for a laser module. During the first run of the machine, the A axis moves only in one direction, and I start to check all the connections. Since everything seems to be correct, I’ve measured the port with a multimeter and noticed that the level is always ~5V. I’ve assigned the Pin to M10.1/M11.1 command and the state changes also in the “Diag” view, but the multimeter shows always ~5V. Then I used the output 1 on Port 3 (Extension Output) and everything worked fine and the state changes. During the testes I also noticed that the output 17 on port 1 is always shown as “red/HIGH”. I’ve start also controlling this pin manually (assign to laser, M3, and M10 Q200 / M11) but this output never changes to “low / gray” in the Diag view. Measuring the port with the multimeter shows always near 0V and therefore the opposite behaviour of output 16. To validate my command from a software perspective, I’ve assigned output 2 port 3 to the laser and everything worked as expected.
Questions:
1. Are there known issues with these outputs or are there any proposals to fix the issue?
a. Could it be a software/configuration issue or is the HW damaged?
2. If it’s a hardware fault, are there any disadvantages in using Port 3 Pins for the laser PWM and DIR pin without further extension port?
Regards
