Probing problems
Probing problems
Postby dhb9mm@gmail.com » Tue Apr 05, 2022 4:44 pm
when i try to probe in Z it comes down and touches my plate. it rejesters that it touches, even though i have the box selected for it to save the offset to the Z, it does not. it does not retract, and do a second touch. matter of fact it just sits there on my touch plate and does not retract at all. I have to hit the reset button, and then raise my Z up off the touch plate. I have retract enable also.it does not save the offset to any of the tool numbers either.
dhb9mm@gmail.com
Re: Probing problems
Postby dezsoe » Thu Apr 07, 2022 10:58 am
Please, upload your profile and I'll check your settings.
Usually the Enable retract is not needed. If the Single probe mode is not turned on and the Fine distance is set then it will retract for the second probe. Turn on the Zero probed axes to zero the probed axes. You may turn on Zero on all offsets if needed. The probe screen does not change the tool table now, but it will in the future.
Postby dhb9mm@gmail.com » Thu Apr 07, 2022 2:15 pm
The zero probed axis button is turned on but it does not zero it. It comes down and touches the part, the probe touching light comes on and the machine just sits there. It won't let me zero it either until I click program stop button.then I zero the Z axis and manually retract it.
dhb9mm@gmail.com
Postby dezsoe » Thu Apr 07, 2022 2:47 pm
I can't check your settings without the profile. Beleive me, I know how the probe screen works.
Postby dhb9mm@gmail.com » Thu Apr 07, 2022 4:07 pm
How do I find my profile file to send it to you then so you can help me figure out what I have set wrong?
dhb9mm@gmail.com
Postby dezsoe » Thu Apr 07, 2022 4:17 pm
Postby dhb9mm@gmail.com » Thu Apr 07, 2022 6:41 pm
Yes that's what I am asking you.
dhb9mm@gmail.com
Postby A_Camera » Thu Apr 07, 2022 7:49 pm
dhb9mm@gmail.com wrote:Yes that's what I am asking you.
It's a link. Click on it and you'll get the answer.
Postby dhb9mm@gmail.com » Thu Apr 07, 2022 10:32 pm
i am running version 1.2113
I have attched my profile I use. Thanks for your help. I am sure I have a setting wrong somewhere I just dont know where. whlie you are looking at this, can yuo see if there is a setting that when i home the machine it will do it 2 times to get a more acurate setting?
SuperBee.pro
(37.64 KiB) Downloaded 225 times
dhb9mm@gmail.com
Postby ger21 » Fri Apr 08, 2022 11:03 am
if there is a setting that when i home the machine it will do it 2 times to get a more accurate setting?
There's no need to home twice. Just lower your backoff speed.
Users browsing this forum: No registered users and 47 guests
