UCxx device was not found
Postby chochanghyun » Sun Jan 23, 2022 7:42 am
"UCxx device was not found" Any solution to this message?
Even if I set ip to 10.10.10.10 and subnet 255.255.255.0 according to the manual, my PC still cannot find the card ip.
Maybe the card is broken?
chochanghyun
Re: UCxx device was not found
Postby cncdrive » Sun Jan 23, 2022 3:12 pm
You setup what to IP 10.10.10.10 ? The network card IP or the motion controller device IP?
The network card IP has to be 10.10.10.10 and the motion controller device IP has to be 10.10.10.11
Postby chochanghyun » Mon Jan 24, 2022 2:26 am
Naturally, I set my PC's IP to 10.10.10.10.
I have reset UC300ETH-5LPT to factory and tried all possible means such as disabling the firewall,
but UCxxx_utility.exe still does not recognize UC300ETH-5LPT.
It seems that the information such as the IP address on the board is broken.
If so, is there any way to solve this?
chochanghyun
Postby cncdrive » Mon Jan 24, 2022 3:46 am
Doing a reset on the UC300ETH puts the default IP address back to the UC300ETH, it is 10.10.10.11.
The utility tool sends broadcast messages to explore the UC300ETH.
This means that the device will receive these messages even if the IP address is set incorrectly.
The only case when it does not receive the message if there is an IP conflict of 2 devices on the same network, e.g. if the computer has the same IP address as the UC300ETH.
If the utility tool does not find the device then it can be that:
- The IP address of the UC300ETH and the computer is the same. (assuming you have direct cable connection to the computer.)
- The ethernet cable is broken.
- The ethernet cable has wrong pinout.
- The UC300ETH is broken.
Postby Cmore » Mon Jan 24, 2022 7:27 am
I've got an AXBB-E with a similar issue. Device can't be found after regular use for two years and no issues connecting in the past (with nothing changed!). I've tried another computer, different ethernet cables etc.. 24v & ready light are on, with no fault on 5v either. I've tried the utility with all the above changes and not once has the blue link light flashed from the scan. Is there anything left to try?!
Cmore
Postby chochanghyun » Mon Jan 24, 2022 12:01 pm
Thank u
chochanghyun
Postby cncdrive » Mon Jan 24, 2022 12:49 pm
If your computer network card is working and your ethernet cable is OK and if the utility tool does not find the device after doing a reset on it then your controller has somekind of defect.
Then the only thing you can do is sending it to us for checkup and possible repair.
Postby chochanghyun » Mon Jan 24, 2022 1:00 pm
thank you Finally, I'll buy a new crossover lan, test it out, and if it doesn't work I'll send it to you for repair.
chochanghyun
Postby Cmore » Wed Jan 26, 2022 2:44 am
Thank you. How do I go about sending it in for checkup and possible repair? Do I need to contact my re-seller as well?
Cmore
Postby cncdrive » Wed Jan 26, 2022 5:35 am
You can send it to our postal address:
CNCdrive Kft
7833 Gorcsony
422/4 Hrsz
Hungary
E-mail: info@cncdrive.com
Phone: +36-70-904-0565
If you sending it from outside the European Union then please declare that the device is for repair and declare 0 value, otherwise we will have to pay 27% VAT + 3% tax for the import.
Users browsing this forum: No registered users and 46 guests
