The mystery of Output 8
Postby TroyO » Sun Jan 16, 2022 9:49 pm
I’ve just got a UC300 and UCSB breakout board and I’m just starting to setup/test/connect stuff.
In the UCSB, Output 8 is on with nothing more than power (24vdc) connected. When I connect the UC300, and set up some pins in axis config I can see the flicker on the step pin, and on/off with the one set as dir.
Output 8, though is non-responsive and basically just always stays on.
Thoughts, ideas or suggestions?
TroyO
Re: The mystery of Output 8
Postby TroyO » Thu Feb 03, 2022 4:51 pm
I still don't have a resolution for this problem. I've emailed a few times and posted here and haven't heard anything back.
O8 is always on. Even with only 24v applied.
When the UC300eth is hooked up It doesn't respond to any signals. (I can flip it's neighbors without any issue.)
Can someone help me out? I don't think there's firmware on the breakout board, or any kind of reset procedure but if there is please let me know. If not, I'd like a replacement board.
The order email address is troyollom@hotmail.com
Troy
TroyO
Postby dezsoe » Sat Feb 05, 2022 4:33 pm
This is a faulty board. With the ribbon cable not connected it should not have an active output.
Postby TroyO » Tue Feb 08, 2022 11:12 pm
That's what I think too. I'll keep emailing, maybe I'll get something back.
TroyO
