UCR201 Plugin versions
Postby mark68 » Thu Dec 30, 2021 10:48 pm
Hi, in version 1.2113 of UCCNC my UCR201 plugin is 1.4 beta and looking at version 1.2114 in the test relaease this jumps to V1.8 by the look of it, am i missing some newer version of the plugin since 1.2113 ? If so when will 1.2115 become the replaced stable version please?
mark68
Re: UCR201 Plugin versions
Postby Battwell » Fri Dec 31, 2021 12:36 am
Stay with 2.113 if you use probing
114 and 115 have a bug if ucr201 is used
Postby dezsoe » Thu Jan 06, 2022 12:56 pm
The missing versions were not released.
Postby mark68 » Wed Jan 12, 2022 9:45 pm
dezsoe wrote:The missing versions were not released.
There's quite a few improvements in version 115 for the UCR201, the bug that's mentioned by Branden is this one particular thing if so depending what this maybe something I don't use?
UCR201 1.8
- Enable rewind with stop checkbox.
- Safety button mode to select MPG/keys/all.
- Tabbed window.
- Double-click on function button fields (F1..F5) to pop up a list of functions.
- Probe button can be configured to call M31 or Start probing.
- MPG mode button function can be selected (velocity+step/velocity/step).
- Axis button function can be selected (axis+FRO+SRO/axis).
- Holding the Axis button the axis/FRO/SRO can be selected with the MPG.
- SafeZ button now calls screen button 216 (which calls the M216 macro).
- [UCR201]/SafetyButtonLED=<LED number> can be set in profile to show safety button state.
- GetUSBDevice exception handled.
- Minor fixes.
mark68
Postby dezsoe » Wed Jan 12, 2022 10:34 pm
The problem is not with the changes in UCR201 plugin but something in UCCNC. We try to do our best to find (and fix) the bug.
Postby DavidR8 » Thu Feb 24, 2022 5:50 am
Hi, I'm looking at buying a UCR201 and am wondering if there are updates on this.
DavidR8
Postby cncdrive » Thu Feb 24, 2022 6:10 am
We already fixed the probing bug (that was in the UCCNC side not in the plugin, it was just related to the plugin), but my collegue also rewritting the whole communication protocol, because in some cases with very noisy environments (wireless transmittion noise) it cased issues, so he rewrites the encryption in the communication to make it more bulletproof. This will still take some time to finish, probably about 2 weeks or so.
Postby MikeM » Fri Feb 25, 2022 8:09 am
Would existing UCR201 pendants need updated firmware?
Is there a way to update the pendants if required?
MikeM
Postby fixebr » Fri Feb 25, 2022 11:44 pm
cncdrive wrote:We already fixed the probing bug (that was in the UCCNC side not in the plugin, it was just related to the plugin), but my collegue also rewritting the whole communication protocol, because in some cases with very noisy environments (wireless transmittion noise) it cased issues, so he rewrites the encryption in the communication to make it more bulletproof. This will still take some time to finish, probably about 2 weeks or so.
Tell me, will the problem be solved that in case of operation of SoftLimit, the suspension stopped moving axis in step mode?
fixebr
Postby cncdrive » Sat Feb 26, 2022 2:52 am
The firmware will be updated automatically by the plugin.
Fixebr: I don't understand your question.
Users browsing this forum: Bing [Bot] and 44 guests
