uccnc cant load DXF - recommend alternate program on AXBB_E?
Postby Tillo » Mon Dec 13, 2021 12:01 am
Hello after my old motion controller died i was using mach 3 then after lots of research i decided on uccnc licenced + axbb-e
which i have installed and working however uccnc is comunicating with the axbb-e i can move it around but for the life of me i cannot load a dxf file
i have been stuck on this for 5 weeks and cannot use my table :( & loosing and lost a heap of work
from what i can see is UCCNC can only load DXF file can't load gcode or other files
Wanting what program will save the file into DXF that this UCCNC program will work?
or
Suggesting a better program to use on the AXBB-E?
Thanking you Tillo
Tillo
Re: uccnc cant load DXF - recommend alternate program on AXB
Postby ger21 » Mon Dec 13, 2021 12:17 pm
UCCNC can load g-code. There's no reason to try to load a .dxf file if you have g-code.
Postby cseyler » Mon Dec 13, 2021 4:18 pm
The ability to UCCNC to load DXF is only done through the CAM tool of UCCNC ... it is just a tool.
The normal way is simply loading gcode in uccnc ("load file" button)
cseyler
Postby thegreatwaldo » Mon Dec 13, 2021 7:45 pm
Tillo wrote:Hello after my old motion controller died i was using mach 3 then after lots of research i decided on uccnc licenced + axbb-e
or
Thanking you Tillo
Hi Tilo.
What program/software are you using to design your dxf files. You would normally use your softwares postprocessor to output the file as g code ie,.nc extension or maybe .tap
Cheers.
Andrew
thegreatwaldo
Postby mircea13 » Thu May 19, 2022 6:46 pm
Hi all, I have installed the UCCNC software, UC100 it is connected but I want import my Mach3 profile and I have error about □ in line 1 position 40056, I have checked the code on CC+++ but I don't found nothing wrong and don't import the profile, if I want create new profile I write on the box I request shortcut on display and when I hit create come out message The profile name textfield is empty.
I have reinstalled the software but error persists. Please help me, thank you.
mircea13
Postby mircea13 » Thu May 19, 2022 7:04 pm
I try uploading the pictures,let see if I make.
mircea13
Postby cncdrive » Thu May 19, 2022 8:20 pm
You have to press the enter keyboard key to finsih the input to the profile name draw, this is why you getting that error message in the UCCNC.
The other errer message in MAch3 you getting, because you using a cracked Mach3 license key.
Postby mircea13 » Thu May 19, 2022 8:42 pm
Thank you very much and about crack Mach3 ????. I have paid for the laptop from someone with Mach3 installed but I don't know if it is cracked. Naw need to stay in touch with the seller
It is any chance to import that profile? I start from scratch?????
mircea13
Postby cncdrive » Thu May 19, 2022 8:51 pm
You can purchase a proper mach3 license and install it. Or you could remove the license key (Mach1lic.dat) file in the Mach3 folder and then run Mach3 2 times after that you can import the license file.
Mach3 will then run in demo mode, but your goal is not to impor the profile into UCCNC so it should be not a problem IMO.
Postby mircea13 » Thu May 19, 2022 9:16 pm
Hi, I have sorted out with profile but now when I start the software don't ask me about UC100 in that window start and my CNC doesn't move like I'm not connected
I don't spend another money because I'm ready out of the budget with a new spindle, UC100, and Licence for UCCNC need to make this one working
I tray look to the tutorials to be possible to sort out in some way to make work.
mircea13
Users browsing this forum: No registered users and 47 guests
