Wiring a 5th Axis on Isolated Output - AXBB-E
Postby RRocadas » Fri Nov 05, 2021 11:17 am
Hi there
I have the folow configuration with AXBB-E board with X, Y1, Y2 and Zaxis.
I need to wire a rotary axis and my doubt is if i can wire this rotary axis to 2 pins of isolated outputs.
The imaghe shows how i have the configuration.
Other question is the driver for the rotary axis needs 5volt on Step+ and Dir+, so it's there any problem with this configuration?
THank you in advance for your information.
Ricardo
RRocadas
Re: Wiring a 5th Axis on Isolated Output - AXBB-E
Postby dezsoe » Fri Nov 05, 2021 12:36 pm
This will not work this way, the O1..O8 outputs are open collector outputs. I recommend using the outputs on port #3 if you can connect there.
Postby RRocadas » Fri Nov 05, 2021 5:15 pm
Hi Dezsoe
Thank you i will connect from port #3.
Regards,
Ricardo
RRocadas
Postby RRocadas » Fri Nov 05, 2021 7:52 pm
Hi again
Just remember that since i have y1 and y2 as a slave of y1 axis, can i put this two together receiving same signals to free up to outputs for my rotary axis.
I know that i have to twist o e par on motor side but is this possible?
Thank you in advance.
RRocadas
Postby RRocadas » Sat Nov 06, 2021 5:25 pm
Hi again.
I mean this option.
Is this possible and safe?
RRocadas
Postby dezsoe » Sat Nov 06, 2021 7:39 pm
Yes, it is, but this way you cannot square the gantry.
Postby RRocadas » Mon Nov 08, 2021 9:20 pm
dezsoe wrote:Yes, it is, but this way you cannot square the gantry.
Thank you very much, it's resolved.
Since i'm using just one limit switch for each axis and defined hard limits werever i need to square the gantry, i can use this to free up one axis.
In near future i will buy your breakout board to complete the setup. My gantry is very rigid and it's usualy squared.
Resolved. Thanks
RRocadas
Users browsing this forum: No registered users and 58 guests
