screenset definition : purpose of id
Postby cseyler » Tue Nov 02, 2021 2:07 pm
Hello,
As far as the tabs "labelnumber" represent "layers" on which other controls (like background, button, led,...) can be linked, i don't understand the purpose of the "control id" (background number, button number, ...)
Could you clarify the purpose of these IDs ?
Thanks in advance
cseyler
Re: screenset definition : purpose of id
Postby dezsoe » Tue Nov 02, 2021 3:19 pm
Which function has this parameter?
Postby cseyler » Tue Nov 02, 2021 4:12 pm
void Addbackground(double posX, double posY, double width, double height, int picturenumber, int backgroundnumber, int layernumber)
backgroundnumber ?
Function: void Addmdi(string labeltext, string labelfont, string textalign, int fontsize, int fontcolor, int posX, int posY, int width, int MDInumber, int layernumber)
MDINumber ?
cseyler
Postby ger21 » Tue Nov 02, 2021 7:28 pm
To know which one it is if you have multiple backgrounds.
Postby dezsoe » Thu Nov 04, 2021 12:08 pm
The backgroundnumber is not used, you can simply zero out. (It is there for backwards compatibility.)
The AddMDI function is not used. You can add MDI by placing field 1000.
Users browsing this forum: No registered users and 51 guests
