Arc Ready
Arc Ready
Postby alanmccabe » Sat Oct 30, 2021 6:28 pm
HI all, I want to be able to occasionally run my table without the torch height control Proma 150. My plasma cutter an Oxford 350 has a CNC interface with a built in arc ready signal which I am using. It works ok when in THC mode on UCCNC however when I switch off THC mode the machine starts on it merry way before the arc ready signal and so the plasma cut is missing a few mm at the beginning. I appreciate I can add a dwell time but just wondered is there a way I can make UCCNC no move until that Arc Ready light comes on. Thanks in advance. Alan
alanmccabe
Re: Arc Ready
Postby laki » Sat Oct 30, 2021 7:59 pm
You can create a macro.
int ArcOKInputLED = 97; // Port 3 pin 12 (change to suit your needs )
while (!exec.GetLED(ArcOKInputLED) && !exec.Ismacrostopped())
  // Lets wait hear until we get ARC OK
  exec.Wait(10);
// End and proceed to pierce delay
laki
Re: Arc Ready
Postby alanmccabe » Sun Oct 31, 2021 7:58 am
Thanks Laki, I appreciate this is a real dumb question, I am not sure what to do after I create the macro perhaps you can point me in the right direct. Thanks ALan
alanmccabe
Re: Arc Ready
Postby laki » Sun Oct 31, 2021 9:34 pm
I made a macro M1032 that contains this code.
I use SheetCam to create the G code and I modified the postprocessor so that it inserts a line of M1032 code each time the plasma starts.
You can modify your post processor by adding a line to the OnPenDown function immediately after M03:
post.Text ("M1032 (wait for ARC OK) \ n")
function OnPenDown
post.Text ("\ n M03 \ n")
G code, example:
laki
Re: Arc Ready
Postby alanmccabe » Mon Nov 01, 2021 12:54 pm
Thanks so much Laki
alanmccabe
Users browsing this forum: No registered users and 37 guests
