Slave axis only jogs - does not run in G-code
Postby etagevask » Thu Oct 14, 2021 7:16 pm
Hi all
I have recently bought a UCCNC and killerbee setup and I am now ready to run g-code.
I have used fusion 360 to create g-code.
For some reason the A-axis which is set to slave for the Y-axis under axis settings only jogs, but when running G-code only the Y-axis run.
Any suggestions?
etagevask
Re: Slave axis only jogs - does not run in G-code
Postby etagevask » Sun Oct 24, 2021 7:43 pm
SOLVED!!!!
Turns our UCCNC were set up for running to fast. all axis moved correctly, but to fast and the A axis (and for some reason only the Axis) stumpled at these speed.
I found out as a noticed the joggin mode where set to 10% speed. When pushed to 100% everthing locked up.
I first tuned down the velocity in the "axis setup". Now I got moving and then noticed the movement didn't fit with the expected dictance. I then calibrated the axis and found the number wrong - changed it and where then able to tune up the velocity again.
Maybe I should have noticed this before - but I'm new and really happy to solve this problem :D
etagevask
Postby cncdrive » Sun Oct 24, 2021 11:48 pm
Good to see that you resolved it.
Users browsing this forum: No registered users and 44 guests
