Probing, Vice mounting
Postby Lozza50 » Fri Sep 24, 2021 3:41 am
CNC is Axiom PRO 8 . When mounting vice directly onto aluminium base probe will not work. Puck is directly connected to
Axiom. Have spent many hours looking for a solution.
Lozza50
Re: Probing, Vice mounting
Postby Delco » Sat Sep 25, 2021 10:48 am
You need a isolated touchprobe or if you are using a rod as touchoff then make it insulated from the spindle - you have a circuit going from your spindle to the bed via a earth circuit.
Delco
Postby Lozza50 » Tue Sep 28, 2021 2:01 am
Thanks it worked
Delco wrote:You need a isolated touchprobe or if you are using a rod as touchoff then make it insulated from the spindle - you have a circuit going from your spindle to the bed via a earth circuit.
Lozza50
Users browsing this forum: Baidu [Spider], Bing [Bot] and 41 guests
