uccnc configuration
uccnc configuration
Postby dobrodewed » Tue Jan 03, 2017 4:50 pm
I can't seem to change my configuration settings. How do you do that? If I type in a new one and hit apply , it reverts back to what was stored. Thanks Duane
dobrodewed
Re: uccnc configuration
Postby ger21 » Tue Jan 03, 2017 5:35 pm
Hit the Enter key after typing it in. There's also an option to not require the Enter key.
Postby cncdrive » Tue Jan 03, 2017 9:28 pm
Also you can remove the tick from the Configuration/Appearance/Validate textfields with enter key only checkbox and Apply the settings and then you do not have to press the Enter key,
but the DROs will then validate when you leave the DRO anyways.
Postby dobrodewed » Wed Jan 04, 2017 5:22 pm
the enter key works, but if I close uccnc when I restart it the old settings are back. How do I change them for good. Could it be the stepcraft file loading when I start uccnc?
dobrodewed
Postby ger21 » Wed Jan 04, 2017 7:08 pm
Apply Settings, then Save Settings.
Postby cncdrive » Wed Jan 04, 2017 7:18 pm
If values do not save then you may have the profile file or the UCCNC directory or it's Profiles subdirectory write protected. (Right click, properties, security on the folder/file)
Or your user account in Windows has no rights to write to that folder. You can try to run the UCCNC with administrative rights (right click on the UCCNC icon and run as admin...)
