Huanyang Hy02d223b vfd
Postby zapbrannigan » Tue Aug 10, 2021 6:40 pm
If I get ucnc software and the axbbe controller, will I be able to connect to the Huanyang Hy02d223b vfd?
If so, will I able to control spindle speed from ucnc?
zapbrannigan
Re: Huanyang Hy02d223b vfd
Postby cncdrive » Tue Aug 10, 2021 6:42 pm
If the VFD has an analog input (0-5V or 0-10V) for speed reference then yes you can control it with the AXBB-E and UCCNC.
Postby zapbrannigan » Tue Aug 10, 2021 6:49 pm
Cool. Thanks.
zapbrannigan
Postby zapbrannigan » Sun Aug 15, 2021 1:19 pm
In order to control spindle speed, is the following wiring sequence correct?
VFD and FOR are connected through a normally open 24V relay (output 2 on AXBB-E - Port 1 pin 2).
A01 goes to V1
ACM goes to 5V0 (Power out portion on the AXBB-E)
zapbrannigan
Users browsing this forum: Google [Bot] and 45 guests
